cbchevy4x4
- Joined
- Jun 6, 2020
- Messages
- 133
- Reaction score
- 105
- Points
- 43
Ok I'm done beating this horse.
Problem, bay sits unused for 30 minutes when switched to hp, doesn't matter whether it's hot or cold water both gravity fed, pulsation occurs for 5 seconds. The longer the bay sits un used the longer the pulsation will occur.
Steps taken so far.
Inspected seals and valves...all ok
Swaped pumps between bays. Problem does not follow pump
Swaped unloader between bays. Problem does not follow unloader.
Checked inlets for air suction...nothing.
No water leaks on output side all the way to the bay.
No belt slippage.
It acts like the water in the hose is leaking out of the hose, as when weeps are activated esp overnight the problem does not occur.
I have disconnected both the inlet hose to the pump and the hp hose from the pump to unloader to see if water back flows out of the system going out to the bay. Nothing.
Have shut the bay down overnight left the wand on the floor over night when weeps are not going to see if water drains out that end. I'd see that on my cameras if so... again nothing.
What am I overlooking?
Steps taken so far.
No belt slippage.
