It seemed when we played with that the product that hit the paint first seemed to be most important. So we always used a very strong first pass of high, followed by a much weaker "show pass". For example, lets say you had two mls of presoak to clean with. My tests indicate you would be better off putting 1.25 mls on pass one, then .75 ml on pass two instead of equal amounts on both pases. To demonstrate in hydrominder terms what I mean, instead of equal passes with a brown tip, pass one may have an orange tip, but pass two might use use the same product with a purple tip. To tweak I would try to continue to reduce the strength of pass two until performance drops or the foam production drops to unacceptable levels. Then, if needed, strengthen back up until cleaning returns. Then try the same process with pass one.
Back in 2003 I started boosting alkaline presoaks with caustic. It is essentially the same thing several manufacturers are doing through dual tip eductors with their custom blends. It is a cheap way to increase cleaning performance without adding the foam (which must be rinsed off). I would not recommend it for the causal operator, but by increasing the level of alkalinity you can make darn near any presoak on the market clean better. (I will now await the incoming flak from finger-wagging chemical reps.)
I will also say that clearcoat paint finishes are much tougher than most realize. I use a solution strength that would make most people pass out if they inhaled it, in the high 12's. Most one drum presoaks could be applied at twice the recommended strength or even stronger, and still not hurt the finish. Even the premium clearcoat products (rainx, etc)will survive that bath a couple of times.
Titration is a much more accurate way than ph to determine chemical strength. You may have to develop your own numbers to work by, but if you are planning to use the product over the long term, it is worth it the trouble.
