Caulk
Dirt Buster
I'm looking for a caulk to use with my farmtek polymax boards. The caulk I bought at home depot is already not holding up well in my razor wash. What have you all tried that worked and stayed looking well?
Dirt Buster
I will definitely give the RV Proflex a try! I'll do a test area. Thank you.
3M 5200 is basically permanent. If they still make it try 4200 instead. It is a very similar product but with lower adhesion.
I tried the RV sealant and didn't like the way it laid down. It was too hard to work with.
I bought some ACE brand white 100% silicone bathroom caulk and it applies nicely. I have used the clear version of this in my bays and it lasts a long time and sticks well, too; I use it to adhere signs inside my bays.
I have ALOT of caulking to do so ease of application is key.
Dirt Buster
And it really stays looking nice? I've tried some other brands for regular bathroom caulk and it does not stay looking good.
Not sure yet. I've used the clear and it still looks clear years later, so I think the white should hold up well.
It will have a good long cure period before any dirt and water are introduced to it, so maybe that will help, too.
